WR250 95-96 model water pump
i bought this bike about 1.5months ago it had a bad water pump seal i replaced the water pump seal,oil seal,front and rear bearings,impeller, now when i put the seal,washer,front bearing back into the clutch cover i couldnt get the right impeller clearance so i had to remove the washer behind the water pump seal so now i have the washer takin out and perfect impeller clearance i spoke to the husky mechanic he said it should be ok the bearings shouldnt move has anyone else had this problem? and yes the seal was pressed in as far as it would go :D
