Best hydraulic press for motorcycle repair?
This one is for you motorcycle motor gurus,
I want to buy a hydraulic press for home and don't need an expensive press like the one I use at work (I'm an auto mechanic). I've been shopping around a have found many inexpensive presses starting as low as 100 bucks for a 12ton. I want to be able use this for all kinds of motorcycles not just a DRZ so the question is:::::::Will a 12ton'er be enough for motorcycle repair or should I go for a 20ton or more? What are you gurus using and if there are any presses you recommend because it is motorcycle specific then::::::What is it and where can I get it? I'm also in interested special adaptors that are made to use with a press for rebuilding motorcycle engines so::::::What do you got and where can I get it?
Also:::::Is there a minimum width? What should be the minimum working area of the press be to be a good press for motorcycle repair?
12 ton is plenty.
30 inches seems to ring a bell on width.
Concur, 12 ton will do anything you need done on a bike, and most car apps.
I have a smaller 20 ton, with a 23" wide work area and 33 " deep reach.
What ever you get,, buy a GOOD, flat set of arbor plates.. The cast non machined junk that comes with all cheap presses, and some better ones are not worth the steel they are cast from.
Steel???? Is that what that pot metal is supposed to be :D
Thanks for the quick responses all,
Any you guys got any links to online specialty tool shops that are geared for this and/or motorcycle repair?
Also:::::What's a good minimum press depth that will handle anything a bike might through at me?
As a rule.. the only tool I trust from Harbor Freight is a hammer..... But
http://www.harborfreight.com/cpi/ctaf/Displayitem.taf?itemnumber=32879 32879.gif
This simple 20 ton press has worked very well :D I would never try and use it in a shop, but for occasional home use it does OK.
I bought the same one. There are bolts that go through the frame from front to rear and there's way too much play. I pounded some 1/2" washers in to take out the play and replaced the four through-bolts with eight short bolts. I know that all sounds incomprensible to someone who doesn't have experience with one of those, but those who do will understand.
Other Harbor Freight tools that have served me well:
Motorcycle lift (aluminum):
http://www.harborfreight.com/cpi/ctaf/Displayitem.taf?itemnumber=91960
Digital multimeter (DMM) is fine for car and bike work ($4 when on sale):
http://www.harborfreight.com/cpi/ctaf/Displayitem.taf?itemnumber=92020
Battery load tester ($14 on sale):
http://www.harborfreight.com/cpi/ctaf/Displayitem.taf?itemnumber=90636
Digital calipers ($16 on sale):
http://www.harborfreight.com/cpi/ctaf/Displayitem.taf?itemnumber=47257
(they are every bit as accurate and repeatable as the Mitutoyo calibrated stuff at work. Tried multiple comparisons.)
Big-a$$ slide hammer:
http://www.harborfreight.com/cpi/ctaf/Displayitem.taf?itemnumber=5223
Pulled bearings races when nothing else would. Wouldn't be an everyday tool, though.
They also have a few nice hand tools (and this from someone who has a fair sized collection of SK, Vise Grip, Craftsman, etc. stuff) if you look carefully. Most of it is utter rubbish, but other stuff is getting really good. I was very impressed with their adjustable wrenches. Some of their screwdrivers are good, too. Various socket extensions, wobble adapters, etc. are quite reputable, too.
I have never seen any handheld power tool from them that looked worth carrying to the car if they gave it away. It's scary-bad stuff. In general, if you can't see it in person, don't buy it.
LOL,, You don't own a welder and cutting torch do ya :D
Bolts... What would I need bolts for? :D
Either you guys remember what the shipping was on this 200lb sucker?
About $8 if I remember.
:D
I picked mine up at a local outlet :D
Any of the stores local to you close enough to drive to?
Harbor Freight Retail Store Locations
New York
ALBANY, NY 1770 CENTRAL AVE, STE 4 518-452-3875
BUFFALO,NY 1459 NIAGRA FALLS BLVD 716-835-6435
ROCHESTER,NY 1040 EAST RIDGE ROAD 585-544-5154
SYRACUSE,NY 709 N. MAIN ST. 315-452-9121
UTICA, NY 5127 COMMERCIAL DRIVE 315-736-3984
Yes, I do, but I really hate painting stuff and I hate rust, so I went for bolts.
