Gear For a kid?
I recently bought a used xr70 for my son. I want to get quality safety equipment. Can any body help me as to what brands to stay away from or what brands are good to buy. There seems to be a lot of stuff out there and I'm a little confused. I know to get a dot | snell helmet, but what else should I be looking for. He's 8. Thanks.
Helmet (DUH), Chest Protector, Boots, Jersey, Gloves, Pants, Neck Protector, Goggles, And He Has Everything The Pros Use. Has A Ton Of Equipmentand Free S&h Over $100. "thor" And "fox" Are Probably The Some Of The Best Brands But They're Pretty Much All Good.
just make sure that you let him know how important it is to wear all of his gear all of the time!!! go for the full set-up... after his first big get off, you will be glad....
add shin guards to the list mini thumper made... he will be so glad he has them on if he was anything like me when I started... knees bruised like there was no tomorrow... good luck! :D
well i dunno about you but i would shop and go under gear and look under clearance..all the 04 alloy stuff and some other brands is going for like $5 - $10 bucks a piece..04 alloy jerseys are $10 bucks, gloves are 5..same price for youth
insane deal, i just got a full 04 alloy gear package for like 65 bucks
Thought I'd bring this thread back to life for a moment -- seems a good one, as there really is a ton of gear out there, and the last thing I want is my son wracked up because of my desire to get him riding... What's everyone make of these neck systems that attach to their chest protectors? I don't see a lot of kids with it on, so I thought maybe there's a reason?
I got my son everything, except a neck protector at first. He is very cautious and does not go very fast. Let me tell you he is loving all the gear, helmet, goggles, elbow pads, chest protector, knee pads and boots along with jersey, pants and gloves. He has had some pretty good get offs and has not complained at all. Just gets up and goes back at it because of all the gear. He finally started wheeling/ jumping on some jumps last weekend and started to say his neck hurt. So before the next outing he will have a neck roll. I knew I would be getting him one once he started jumping a little, but until this point he has not complained about it, but that doesn't mean it wouldn't hurt to get them one before hand.
A problem w/ the ones attached to the chest protector is that the chest protector moves around too much under a fall. So the neck padding is likely to be shifted out from under the helmet, and that does it no good.
You'd be better off w/ a dedicated neck support (RC1,RC2) that you know will not roll out from under the helmet, which BTW, is what breaks the broken collar bone under compression.
Makes sense. How is the neck collar for restrictiveness/"bothersomeness"?
  • Similar Content
    • By RCWSO
      I have an 07 CRF70 that I have done the filter pod modificaiton by cutting the extension tube off and I have drilled a couple of holes in the end of the exaust per some instructions on a thread here at TT.
      I have recently had some problems getting the bike to idle consistently. I am wondering if I should try and rejet the bike at all or get a needle from an older carb that is adjustable. I do have a unifilter that I can put in as well with the stock pod that I cut.
      It is not that the bike wont run or start, it just seems to only idle if I turn it up significantly but as soon as I turn it down even 1/8 of a turn it dies. But the idle that I set to keep it running well is too fast as the bike will move forward if in gear and no throttle is applied.
      Any suggestions? Jetting, needle, air screw change with an older carb?
    • By the-new-kid
      hello guys I'm like really new to this, like extremely new but I was going to buy xr-70r from a friend and drop a Lifan 125cc engine in it (here's the link: ). Now the site says its a 4preed trans with normal gear set up (1-n-2-3-4), and manual front clutch, I'm wondering if I need to buy the clutch lever, perch, and cable then connect it all. Then secondly, what pip should I be looking for I'm not sure if the header would have to be a different style or what exactly.... please be patient with me I'm doing the best I can to learn... thanks
    • By anger806
      hi im new to the forum and i am running a stock 2005 crf 50f with pro tapers but no engine mods what size carburetor should i be looking for to get a little more pep out of my motor?
    • By HondaRacer37
      Hey everyone.  Darn glad to have found this forum!
      Just bought my son a 2009 CFR70 (first bike - 8 years old) and the first thing I'm doing is scrapping the factory air box for a UNI pod filter.
      I'm looking for advice on how I can open up/modify the factory exhaust for more performance.  I heard about removing the screen and drilling some holes but have not found those posts. Any specific advice would be greatly appreciated. (Found only a couple performance aftermarket pipes that were very pricey.)
      I'm thinking after the air filter change and pipe opening the main jet size may need to be increased. It's a stock 13mm Keihin carb.  What size is recommended?  Haven't looked at the stock size yet.
      I assume the needle is adjustable on the slide (but don't know if this would do any good or be necessary anyway) and hope there is an air mixture screw somewhere because it seems the carb could use a bit of adjustment now.  Although next to the idle screw it looks like a brass cap or plug rather than a screw. (See photo attached.)
      Thanks for any advice.  It's great to be part of this group.  Ride on!
      Greg in Florida
    • By thousandbuckle
      Hello all, reaching out to you today to get some help with a small project I am trying to do.
      I just bought a 2006 CRF50 for my 3 year old and would like to rig it up with a wireless remote kill switch for those just in case moments. I have the throttle speed screw installed and will limit it that way also but want a back up until she is proficient and I feel confident.
      Since this bike does not have electric start there is no battery. I was wondering if any one has or knows how to rig up a wireless car alarm system to work as a remote kill switch. I know I will need a 12 Volt battery on the bike which I can get. I know there is a product from 3Built that does this but the range is only 250 feet and some say it is even less than that. I was thinking of a car system since the range is usually around 1,000 feet which is overkill but I prefer overkill when it comes to this topic,
      Any DIY thoughts you might have or suggestions would be appreciated.
