Kitaco inner rotor kit just installed need jetting?
Just put this rotor in my 110 super stroker
running like garbage. Is it jetting? i don't have my jets right now so i can't try but i'm guessing thats what it is...
Is there any other possiblities that i should look into? pretty sure my ground is good i've heard that can mess things up.
also if anyone has ENGLISH kitaco inner rotor kit install and timing directions you should hook me up. i was sent Jap. instructions.
far as i can see i have it setup to run at 40* which is 12000 rpm
instructions would be sweet.
thanks
Nate
Was your bike running before you put it in? You shouldn't have to re jet after that. Start with your timing at 0' degreees then go up from there.
