RFS Valve adjustment - again
I just completed my first valve adjustment using the guide in the post on the Holeshot forum. The post, was very informative, but, when I was complete, my valves were ticking. Is this normal, and if not, does this indicate the valves are adjusted too loose? Thanks for any help.
you guessed it!!!! Your valves are not suppose to "tick" when you adjust your valves make sure that their is plenty of drag on your feeler gauge... pactice makes perfect
