400/520 service intervals
I'm having a hard time deciding if I should get a 400 or a 520 and one of the things to consider is of course the maintenance cost.
I've read that there are both a small and a large service kit (with various parts) for both the 400 and the 520 which should be changed every 30 or 60h.
I also read somewhere (can't remember where) that the interval was adjusted for the 01-models making the large service kit needed after 90h instead of 60, is this correct ?
I also remember that the large kit was about half as expensive for the 400 since the 520 included a new piston etc, is this still valid for the 01-models ? Are the prices still the same (almost $1000 for the large 520 kit in sweden...) ? Other things to consider in terms of maintenace costs ?
Many thanks in advance
I have a 400 EXC and I have no clue what kit you are talking about. The RFS are getting a reputation as a very reliable thumper/race bike.
I was waiting for someone to reply because I have a 520 and I don't know what the "kit" is either. Does one of the Dealers on this list know?
Hi there,
I'm running a '01 EXC520 since 03/2001. There are about 2000km on the odometer; the only maintenance I did are:
*serveral oil changes
*checking valve clearance twice
And the bike got heavy load on a 7 day rally in Poland (with deep sand, forrests, swamp and river crossings).
My dealer told me, that NOBODY of his customers included a big repair kit yet.
The small package might be a good deal for clutch maintenance.
Here's the part list I just extracted from my dealers catalog:
400/520 small kit (seems to be identical):
*clutch kit (including steel plates)
*clutch cover gasket
*some other clutch parts (bearings or something)
price: DEM 199,--
---> so it's more a complete clutch repair kit
the big repair kit for the 400EXC:
*same as small kit
*complete gasket set
*bearings counterbalancer
*crankshaft bearings
*new camshaft chain and tightener
price: DEM499,--
the big repair kit for the 520EXC:
*same as the big 400EXC
*piston rod repair kit
price DEM 999,--
I hope I found the right tranalations from German -> English :)
prices are in DEM (actual exchange rate: DEM2,30=1US$)
Hope this helps ...
[This message has been edited by dirtbike (edited 07-16-2001).]
Thanks for the info, so it seems like the service kits are the same for the 01-models.
Did your dealer specify any intervals for the servicve kits (ie have they changed for the 01-models or not) ? Also, does anyone know why the 520 needs a new piston when the 400 doesn't ? On the other hand, if noboby has ordered the large kit then maybe I don't need to bother...
I see in my manual that the 520 has a forged piston while the 400 is cast. Forged pistons are usually fit a little bit looser - perhaps this increases wear and would cause for a change slightly earlier?
  • Similar Content
    • By Ponch
      I have a 2007 450 EXC that I recently installed a new clutch slave cylinder on. Per the 2007 KTM service manual it clearly states that the clutch needs to be filled with hydraulic oil, which I did (magura blood). That was yesterday. I went out to double check the level today and when I removed the cover, the rubber seal was all contorted and out of shape. I then looked at the cover and it's a Brembo clutch and says "DOT 4 brake fluid only".
      I flushed the line and the master cylinder about 7 times with DOT 4 brake fluid and there was no sign of the magura blood left in the system. My question is: other than the rubber boot on the master cylinder, what damage might have been done by putting in the hydraulic oil? It was in for about 24 hours.
      Thanks in advance for any advice!
    • By pumpernickelBrad
      Hi Folks!
      Sorry if there are a bunch of threads already but I used the site's search function and didn't find anything so far...
      I just found a decent deal on a '14 350 EXC-F with 11k km (unknown hours). Has a few goodies including skid plate, hand guards and it's for sale for about $2k CAD less than a '16 with 6k km on it.
      The bike is in showroom condition (appearance) with no indication it has been offroad at all.
      What would be the gotchas that would make this deal realistic? I'm coming from a WR250R where the engine lasts forever, is 11k street kms high for these bikes?
      Are there any big defects in the '14s that I haven't dug up yet?
      With no service records what things should be done, checked, etc?
    • By Brannnt
      I purchased an '06 525 EXC some time ago, and recently pulled the motor out of the frame to address some other issues. When I removed the clutch slave cylinder, I noticed an issue the previous owner neglected to tell me about during the purchase.
      It appears that at some point, the chain broke and damaged the engine case near the clutch slave cylinder (see pics, please). I have noticed that the clutch does not fully disengage (bike lurches a bit going into gear, neutral is hard to find... its worse when engine is cold) ... I did not notice any leaks around this area (mineral oil or engine oil) before or during disassembly.
      The previous owner (or someone) repaired it with some sort of epoxy.
      Without doing my due diligence (checking clutch fluid level, bleeding) I hesitate to state that this is the cause of my clutch disengagement issue ... but pardon my ignorance here and help me out: How bad is this?  Am I looking at replacing my engine case here or is the previous owner's jerry rig good enough?
    • By Black Sox
      Just bought a new 2017 350 excf ,will be doing 98% off road ,ordered skid plate bark busters ,
      my ? Is what's the best easiest way to eliminate rear fender light assembly.I still would like to have a break light.
      xcf fender will fit so dealer says,under $50.00 👍But xcf brake light $125.00 .👎What's the best economical way of doing this?
    • By JNV
      Hi friends from Spain.
      Mi new KTM
