640 Supermoto vibration
Hi ,
A friend og mine just bought a new 640 (LC4). He is complaining about the amount of vibration he feels through the saddle , after a 30 mile ride his "groin area" was completely numb !. The vibration increases with engine speed. Can anyone tell me if this is normal for the LC4 based models ?
Thanks .
Jerry (on behalf of "numbnuts" :)
I've complained about the same with my LC4 - to no avail. Some recommendations have included softer seat foam (see earlier posts) and standing up more. Don't know if I've finally broken the foam in or what, but it doesn't bother me as much now as 16 months ago when the bike was new off the floor. I probably don't ride it the same, either, as then and both get up on the pegs and vary the RPM's more (gassing it).
Tell what's-his-nuts "Welcome to The Monkey Butt Club"! :)
'98 RXC 620
Thanks KatoomRXC , your answer kind of assures him that its not mechanical trouble causing it. The dealer told him that its normal , but seeing as he´s owned and ridden all kinds of bikes from old British singles and twins to drag race Harleys and not experienced these kind of nut-numbing vibes before , he needed the opinion of other owners. Do you have any idea what causes the vibration ?
By the way , he has been welcomed to the Monkey-butt Club and will probably be cruising this site himself soon. Thanks again.
No idea why, really. I'd just be guessing. My previous bike was an XL600R - affectionately known as 'The Couch'. It didn't have anything resembling my RXC's vibration.
If pressed, I'd guess it's related to higher quality, more rigid handlebars, combined with a shorter stroke. The Honda had dampening weights in the handlebar ends, too, which no doubt made some difference.
'98 RXC 620
[This message has been edited by KatoomRXC (edited 07-18-2001).]
This is Numb Nuts in person,thanx Katoom for welcoming me to the MBC .Is there a membership fee ? and if so, is one of those "blow up cushions" with a hole in the middle included in the fee ?
Thanx also for the reassuring reply , I really thought something was wrong and the dealer was just B-S ing me.
Also ,Jerry ,Thanx a Million ...
Katoom RXC ,
Love the picture , gotta get me one of those LC4´s :)
Numb nuts , as always , you´re welcome.
  • Similar Content
    • By Ponch
      I have a 2007 450 EXC that I recently installed a new clutch slave cylinder on. Per the 2007 KTM service manual it clearly states that the clutch needs to be filled with hydraulic oil, which I did (magura blood). That was yesterday. I went out to double check the level today and when I removed the cover, the rubber seal was all contorted and out of shape. I then looked at the cover and it's a Brembo clutch and says "DOT 4 brake fluid only".
      I flushed the line and the master cylinder about 7 times with DOT 4 brake fluid and there was no sign of the magura blood left in the system. My question is: other than the rubber boot on the master cylinder, what damage might have been done by putting in the hydraulic oil? It was in for about 24 hours.
      Thanks in advance for any advice!
    • By pumpernickelBrad
      Hi Folks!
      Sorry if there are a bunch of threads already but I used the site's search function and didn't find anything so far...
      I just found a decent deal on a '14 350 EXC-F with 11k km (unknown hours). Has a few goodies including skid plate, hand guards and it's for sale for about $2k CAD less than a '16 with 6k km on it.
      The bike is in showroom condition (appearance) with no indication it has been offroad at all.
      What would be the gotchas that would make this deal realistic? I'm coming from a WR250R where the engine lasts forever, is 11k street kms high for these bikes?
      Are there any big defects in the '14s that I haven't dug up yet?
      With no service records what things should be done, checked, etc?
    • By Brannnt
      I purchased an '06 525 EXC some time ago, and recently pulled the motor out of the frame to address some other issues. When I removed the clutch slave cylinder, I noticed an issue the previous owner neglected to tell me about during the purchase.
      It appears that at some point, the chain broke and damaged the engine case near the clutch slave cylinder (see pics, please). I have noticed that the clutch does not fully disengage (bike lurches a bit going into gear, neutral is hard to find... its worse when engine is cold) ... I did not notice any leaks around this area (mineral oil or engine oil) before or during disassembly.
      The previous owner (or someone) repaired it with some sort of epoxy.
      Without doing my due diligence (checking clutch fluid level, bleeding) I hesitate to state that this is the cause of my clutch disengagement issue ... but pardon my ignorance here and help me out: How bad is this?  Am I looking at replacing my engine case here or is the previous owner's jerry rig good enough?
    • By Black Sox
      Just bought a new 2017 350 excf ,will be doing 98% off road ,ordered skid plate bark busters ,
      my ? Is what's the best easiest way to eliminate rear fender light assembly.I still would like to have a break light.
      xcf fender will fit so dealer says,under $50.00 👍But xcf brake light $125.00 .👎What's the best economical way of doing this?
    • By JNV
      Hi friends from Spain.
      Mi new KTM
