RFS Valve adjustment
Originally posted by TBob:
I did mine at around 250 miles but I think
between 300-500 would be o.k.
Here is how http://www.holeshotforum.com/ubb/Forum8/HTML/000210.html
A buddy of mine has a 400 and he say's they
don't need to be done very often after that
he does his every 2k - I think I will do mine every 1. Make sure your read the second post by jeb. If you do take it - take the seat/tank/radators off and a shop shouldn't charge more than a 1/2 hr.
Thanks TBob, I know I should do this adjustment myself. I thought for the fist time I would have the dealer adjust the valves. I was a little shocked when they wanted 1.5 hrs @ $65 per hr plus parts. It only takes a couple minutes to take the seat and tank off and then one again...wonder what they will do the remaining 86 minutes?
Larry
TBob...do you use Solid Works?
TBob
"01" KTM 520 EXC
Mesa, AZ
[/b]
If they remove the radiators, which they should, it takes time. They have to drain them, remove them, etc. I don't leave the radiators in place anymore. It's a pain to work around them. I'm sure I spend 1-1.5 hours on a valve adjustment.
John Brunsgaard
jejb@att.net
01 400 EXC, 99 250 EXC (gone), 99 200 EXC, 98 125 EXC, 98 380 MXC (long gone)
Larry - Solid Works?? don't know what your refering to.
TBob, Noticed you are a CAD designer. Solid Works is a 3D solid Modeler for mechanical engineering.
I used AutoCad - a little Pro-E and Cadence
TBob
"01" KTM 520 EXC
Mesa, AZ
