bringing home the beast
1. With KTM what's to be expected as far as initial factory setup is concerned (been on hondas for the past 20years). Do I take the bike out and ride it weekend #1, or, instead take it apart, lubricate it, tighten its bolts, oil its filter etc.
2. What's the concensus on proper break-in and oil changes. Have heard to stay away from re-useable filters for 10 oil changes or so. What do you guys think?
3. whats the drill for setting preload on a linkless shock system. Same?
enough for now.
thanks fellas
Follow the stuff in the manual.
First oil change will take you a while :D needs to been done in the first three hours. When you clean the screens don't use anything that will eat the O-rings...REMEMBER TO BOLT THE BRAKE RESEVOIR BACK UP ( DON'T ASK! )
Bikes come greased. Watch the rear sprocket bolts, been told they come loose but haven't seen it on mine....
When you set the preload on the shock be careful not to OVER TORQUE the set screw, you can crack the ring....
Chris in the Mojave
'01 520 MXC
'01 200 MXC
'00 CR250R
'01 KX85
Be sure to loctite your kick-starter, mine fell off one day in the pits. It was a good thing it didn't fall off on the track. Also, keep an eye on the spokes, I can't believe how fast they loosen on this bike - I tighten mine every ride. You're going to love your new toy. Good luck.
LOC-TITE anything that has threads!!!! Heck, I had my front engine mount bolt come loose, in the Ny-Lok nut!! If it hadn't been for some good engineering (an oxymoron in most any case)the bolt would have fallen out, as well as the nut, except that the nut is tanged in, and the bolt is attached from the inside. Since, I have had 5 bolts vibrate loose. This thing just eats itself apart!! Love it though :) I since have blue loc-tited EVERY bolt on the beast,
'01 KTM 520 SX
'95 KX 250
AMA Dist 6 Member
Hare Scramble Class B #523
I took my 02 520 for it's first ride yesterday. Rode it for 10 minutes and checked the bolts.
Found that I lost 0ne lower clamp bolt for the front shocks and one of the carby bolts had come very loose.
So it is always a good idea to loc-tite all the bolts even before you ride it because it only took 10 minutes for mine to vibrate loose.
Make sure you check all bolts before you take it out - I rode a 2002 400 last week and it was straight from the crate - oil banjo bolt on top of engine came loose and pumped a lot of oil over the cases. Aside from that this is the best bike I have ridden - the suspension is a mile ahead of the 01's - or maybe I have just got quicker and hit things hard enough now.
  • Similar Content
    • By Ponch
      I have a 2007 450 EXC that I recently installed a new clutch slave cylinder on. Per the 2007 KTM service manual it clearly states that the clutch needs to be filled with hydraulic oil, which I did (magura blood). That was yesterday. I went out to double check the level today and when I removed the cover, the rubber seal was all contorted and out of shape. I then looked at the cover and it's a Brembo clutch and says "DOT 4 brake fluid only".
      I flushed the line and the master cylinder about 7 times with DOT 4 brake fluid and there was no sign of the magura blood left in the system. My question is: other than the rubber boot on the master cylinder, what damage might have been done by putting in the hydraulic oil? It was in for about 24 hours.
      Thanks in advance for any advice!
    • By pumpernickelBrad
      Hi Folks!
      Sorry if there are a bunch of threads already but I used the site's search function and didn't find anything so far...
      I just found a decent deal on a '14 350 EXC-F with 11k km (unknown hours). Has a few goodies including skid plate, hand guards and it's for sale for about $2k CAD less than a '16 with 6k km on it.
      The bike is in showroom condition (appearance) with no indication it has been offroad at all.
      What would be the gotchas that would make this deal realistic? I'm coming from a WR250R where the engine lasts forever, is 11k street kms high for these bikes?
      Are there any big defects in the '14s that I haven't dug up yet?
      With no service records what things should be done, checked, etc?
    • By Brannnt
      I purchased an '06 525 EXC some time ago, and recently pulled the motor out of the frame to address some other issues. When I removed the clutch slave cylinder, I noticed an issue the previous owner neglected to tell me about during the purchase.
      It appears that at some point, the chain broke and damaged the engine case near the clutch slave cylinder (see pics, please). I have noticed that the clutch does not fully disengage (bike lurches a bit going into gear, neutral is hard to find... its worse when engine is cold) ... I did not notice any leaks around this area (mineral oil or engine oil) before or during disassembly.
      The previous owner (or someone) repaired it with some sort of epoxy.
      Without doing my due diligence (checking clutch fluid level, bleeding) I hesitate to state that this is the cause of my clutch disengagement issue ... but pardon my ignorance here and help me out: How bad is this?  Am I looking at replacing my engine case here or is the previous owner's jerry rig good enough?
    • By Black Sox
      Just bought a new 2017 350 excf ,will be doing 98% off road ,ordered skid plate bark busters ,
      my ? Is what's the best easiest way to eliminate rear fender light assembly.I still would like to have a break light.
      xcf fender will fit so dealer says,under $50.00 👍But xcf brake light $125.00 .👎What's the best economical way of doing this?
    • By JNV
      Hi friends from Spain.
      Mi new KTM
