Just took my new 520EXC out for the first run, and love it! Coming off a '99 YZ400 and love the power delivery, ergonomics, and of course the magic button. I am worried about the suspension living up to the YZ's flawless performance through rough terrain, but I am confident I can set it up nice. Ordered the MXC gas tank for long distance rides, the hardware to mount my Scott’s dampener, a Shark fin, a bash plate, and hand guards. I feel like a little kid, I keep sneaking out into the garage and sitting on it or starting it. I go on an annual 150 mile a day trip in Baja next month, which was a little torturous on the YZ, cannot wait this year. Hope everyone else is as happy with his or her KTM. Bill
For me a double means getting both wheels off the ground.
WOW, sounds like a great bike. Enjoy
(AMA, Dist.36, BRC) Lifetime Memberships
I also just got my 520EXC last week. Have only ridden it 3 times but am very impressed with it. Alot more forgiving in the woods than my CR 250 is and the weight is carried so low that it feels like it weighs about the same as the CR. Really amazed at how easy it starts compared to my wifes YZF250. Really not wanting to bash this beautiful piece of machinery as much as I have my CR and my XR 400. I would just hate to see it get that flogged. hehehehe...but I know that eventually it will.
  • Similar Content
    • By Ponch
      I have a 2007 450 EXC that I recently installed a new clutch slave cylinder on. Per the 2007 KTM service manual it clearly states that the clutch needs to be filled with hydraulic oil, which I did (magura blood). That was yesterday. I went out to double check the level today and when I removed the cover, the rubber seal was all contorted and out of shape. I then looked at the cover and it's a Brembo clutch and says "DOT 4 brake fluid only".
      I flushed the line and the master cylinder about 7 times with DOT 4 brake fluid and there was no sign of the magura blood left in the system. My question is: other than the rubber boot on the master cylinder, what damage might have been done by putting in the hydraulic oil? It was in for about 24 hours.
      Thanks in advance for any advice!
    • By pumpernickelBrad
      Hi Folks!
      Sorry if there are a bunch of threads already but I used the site's search function and didn't find anything so far...
      I just found a decent deal on a '14 350 EXC-F with 11k km (unknown hours). Has a few goodies including skid plate, hand guards and it's for sale for about $2k CAD less than a '16 with 6k km on it.
      The bike is in showroom condition (appearance) with no indication it has been offroad at all.
      What would be the gotchas that would make this deal realistic? I'm coming from a WR250R where the engine lasts forever, is 11k street kms high for these bikes?
      Are there any big defects in the '14s that I haven't dug up yet?
      With no service records what things should be done, checked, etc?
    • By Brannnt
      I purchased an '06 525 EXC some time ago, and recently pulled the motor out of the frame to address some other issues. When I removed the clutch slave cylinder, I noticed an issue the previous owner neglected to tell me about during the purchase.
      It appears that at some point, the chain broke and damaged the engine case near the clutch slave cylinder (see pics, please). I have noticed that the clutch does not fully disengage (bike lurches a bit going into gear, neutral is hard to find... its worse when engine is cold) ... I did not notice any leaks around this area (mineral oil or engine oil) before or during disassembly.
      The previous owner (or someone) repaired it with some sort of epoxy.
      Without doing my due diligence (checking clutch fluid level, bleeding) I hesitate to state that this is the cause of my clutch disengagement issue ... but pardon my ignorance here and help me out: How bad is this?  Am I looking at replacing my engine case here or is the previous owner's jerry rig good enough?
    • By Black Sox
      Just bought a new 2017 350 excf ,will be doing 98% off road ,ordered skid plate bark busters ,
      my ? Is what's the best easiest way to eliminate rear fender light assembly.I still would like to have a break light.
      xcf fender will fit so dealer says,under $50.00 👍But xcf brake light $125.00 .👎What's the best economical way of doing this?
    • By JNV
      Hi friends from Spain.
      Mi new KTM
