520EXC Front Wheel Hub Question
Does anyone know if the hub is different on an "SX" since their is no odmeter spacer? Or is there a spacer that could replace the odometer bushing? Need to run reg sx wheel and disconnect odometer....
The hub is different on the SX however; the MXC's do come with a spacer that allows you to remove the odo housing and install the spacer.
