2002 520SX $6200
somebody buy this please! Just had my wrist fused and my bikes need to be sold. My loss is your gain on this one. 2002 520SX with 2 rides. Just changed the oil and filters. Not even a scratch on this thing. The only thing I've done to the bike is put Nstyle number backrounds on and replaced the grips with 909 grips. my phone # is 541-928-2634 (Tangent, Oregon) ask for Rob
PS I also have 2001 CR250, 2001 YZ250, and a 2000 KTM 300EXC for sale if interested. $4300,$4300, and $3800 respectively.
Come on! is my price too high? I'll take $6000 but that's the lowest.
Awesome prices. I'd think you'd sell them at those prices.
Sorry to hear about the wrist.
Good luck.
John Brunsgaard
01 400 EXC, 99 250 EXC (gone), 99 200 EXC, 98 125 EXC, 98 380 MXC (long gone)
  • Similar Content
    • By Ponch
      I have a 2007 450 EXC that I recently installed a new clutch slave cylinder on. Per the 2007 KTM service manual it clearly states that the clutch needs to be filled with hydraulic oil, which I did (magura blood). That was yesterday. I went out to double check the level today and when I removed the cover, the rubber seal was all contorted and out of shape. I then looked at the cover and it's a Brembo clutch and says "DOT 4 brake fluid only".
      I flushed the line and the master cylinder about 7 times with DOT 4 brake fluid and there was no sign of the magura blood left in the system. My question is: other than the rubber boot on the master cylinder, what damage might have been done by putting in the hydraulic oil? It was in for about 24 hours.
      Thanks in advance for any advice!
    • By pumpernickelBrad
      Hi Folks!
      Sorry if there are a bunch of threads already but I used the site's search function and didn't find anything so far...
      I just found a decent deal on a '14 350 EXC-F with 11k km (unknown hours). Has a few goodies including skid plate, hand guards and it's for sale for about $2k CAD less than a '16 with 6k km on it.
      The bike is in showroom condition (appearance) with no indication it has been offroad at all.
      What would be the gotchas that would make this deal realistic? I'm coming from a WR250R where the engine lasts forever, is 11k street kms high for these bikes?
      Are there any big defects in the '14s that I haven't dug up yet?
      With no service records what things should be done, checked, etc?
    • By Brannnt
      I purchased an '06 525 EXC some time ago, and recently pulled the motor out of the frame to address some other issues. When I removed the clutch slave cylinder, I noticed an issue the previous owner neglected to tell me about during the purchase.
      It appears that at some point, the chain broke and damaged the engine case near the clutch slave cylinder (see pics, please). I have noticed that the clutch does not fully disengage (bike lurches a bit going into gear, neutral is hard to find... its worse when engine is cold) ... I did not notice any leaks around this area (mineral oil or engine oil) before or during disassembly.
      The previous owner (or someone) repaired it with some sort of epoxy.
      Without doing my due diligence (checking clutch fluid level, bleeding) I hesitate to state that this is the cause of my clutch disengagement issue ... but pardon my ignorance here and help me out: How bad is this?  Am I looking at replacing my engine case here or is the previous owner's jerry rig good enough?
    • By Black Sox
      Just bought a new 2017 350 excf ,will be doing 98% off road ,ordered skid plate bark busters ,
      my ? Is what's the best easiest way to eliminate rear fender light assembly.I still would like to have a break light.
      xcf fender will fit so dealer says,under $50.00 👍But xcf brake light $125.00 .👎What's the best economical way of doing this?
    • By JNV
      Hi friends from Spain.
      Mi new KTM
