05 rmz 250 popping out exaust on decel
o5 rmz 250 popping on decel, jetting problem? it has the stock jets in it, any sugestions? :D
Check to see if you have an exhaust leak anywhere. Also check the valves. Mine was doing that when the cam timing was off.
Did it just start doing it? Or has it always popped? My 05 KXF did the same thing from day one. The dealer told me they all do it. I've got plenty of hours on mine, if it caused problems I would know by now.
Change the pilot to a 42, fuel screw 2 turns out, you will be fine. I had the same problem when I first got my bike.
Again, this is a question of every "new" 250F owner, if you are "new". If you came off a 2 stroke like I did, It will take a while to get used to the power curve and gear position. You can do some jetting and carb tuning that will help. As well you can change the pipe and silencer. But before I would do that, get used to it. These bikes like to be short shifted, and you dont have to down shift like a 2-stroke. This is absolutely normal. :D
