Just installed the 520 electric fan!! cool!!
That fan is awesome!!! When I ride with my wife on her xr100, my 520EXC wont overheat anymore.
Hi Dr.s,
I ordered my fan last week and it should be here tomorrow. Any tips on the install, or should it just bolt on?
I'm new to KTM's and don't have my manuals yet. How do you know when the bike has overheated? My wife and daughter are on small bikes, so I'll be doing a fair amount of slow riding.
Was your bike overheating when riding with your wife? What year is your 520?
I've never overheated my bike and I've ridden some LONG slow trailrides with my wife, worked on trails, etc. I guess we don't see a lot of hot days up here but we had our share of hot days up here this summer. All my KTM 2 strokes overheated a bit almost every ride so I've been very happy with the 400. It's never used a drop from overheating.
John Brunsgaard
01 400 EXC, 99 250 EXC (gone), 99 200 EXC, 98 125 EXC, 98 380 MXC (long gone)
just because it's not spitting fluid
doesn't mean it's running as cool as it should. The nice part about the fan is that with it "I believe" the motor will last longer because it is running cooler. The fan kicks on at 185 degs. You won't boil over (depending on your set-up) till 230+. Just like an auto trans the cooler you can keep it the longer it will last. my 02
"01" KTM 520 EXC
Mesa, AZ
The cooling fan does work, worked so well on my 520 that it ran down the battery. At least it starts easy with the kick starter, but I'm spoiled.
For the next ride I wired an on-off switch into the line to the fan so I could control when it ran. Every time I switched it on, it would run continuously. The fan and switch are now back in the box.
[This message has been edited by John (edited October 15, 2001).]
My fan works perfectly...
drcrashr--The install was "extremely" easy, the only hard part was reconnecting the right side radiator hose after cutting it about 1"....you have to leave the end of the hose cut at the right angle, or the tube clamp wont hold on right.
Dirtbike Dad--The bike should rest cold with the water level 10 mm above the fins inside when you take the cap off.... If it is lower, you are loosing a little water
jeb--The Bike didn't "overheat" before I bought the fan, but the coolant level would drop some....
John--Maybee someone else on the forum would like to buy your fan kit from you??? Is it in perfect condition with all the parts??
Personally, I love the fan, it seldom kicks on, but when it does I can relax becuase I know my brand new, shiny, beautifull, fast, awesome, rocketship, most fun bike I have ever owned, 02 KTM 520EXC is safe and wont overheat and blow up.
five smiley's
Oh yeah,
John--When I bought my 520, the dealership pointed out that the charging system on the bike is only designed to keep a battery charged, not charge it when it's low....
I bought a little battery charger, charged it once, and it starts perfectly every time, fan or not.."It used to almost never start with the button when I first got my bike"
You might buy a battery charger, and give it one really good charge. It made a HUGE difference for my bike....
My stator has been rewound to put out a 140watts as part of my dual sport kit installation and I love my fan. My bike used to loose coolant slowly when ridden but after the fan install it never needs coolant and I was suprised at how often the fan runs. I love my fan and its automatic operation.
First let me say I'm not putting down the fan. I'm just curious if any of the '01+ bikes are overheating in normal use. I just haven't heard of many instances of it. If you leave them idle for a while, I've heard of them boiling but it's not common otherwise.
I'm not sure I agree with that. I'd sure hope the engineers/designers setup the cooling pressure system to blow by the cap when the engine temps are higher than they 'should' be.
John Brunsgaard
[This message has been edited by jeb (edited October 16, 2001).]
Does the fan fit both the EXC and MXC, or does the bigger MXC tank interfere?
man, after hearing this, I hope I won't hear any more snide comments from KTM 4 strike guys about all the "stuff" we put on our YZF's.
<BLOCKQUOTE><font size="1" face="Verdana, Helvetica, sans-serif">quote:<HR>Originally posted by Steve49:
it fits also on the MXC tank .
I use also the fan, but he is running only in very difficult conditions and i never had problems with the battery.
If the fan is running ( that means the water is very hot , nearly to hot ) you should not stop the engine, because than it cools down faster.
  • Similar Content
    • By pumpernickelBrad
      Hi Folks!
      Sorry if there are a bunch of threads already but I used the site's search function and didn't find anything so far...
      I just found a decent deal on a '14 350 EXC-F with 11k km (unknown hours). Has a few goodies including skid plate, hand guards and it's for sale for about $2k CAD less than a '16 with 6k km on it.
      The bike is in showroom condition (appearance) with no indication it has been offroad at all.
      What would be the gotchas that would make this deal realistic? I'm coming from a WR250R where the engine lasts forever, is 11k street kms high for these bikes?
      Are there any big defects in the '14s that I haven't dug up yet?
      With no service records what things should be done, checked, etc?
    • By Brannnt
      I purchased an '06 525 EXC some time ago, and recently pulled the motor out of the frame to address some other issues. When I removed the clutch slave cylinder, I noticed an issue the previous owner neglected to tell me about during the purchase.
      It appears that at some point, the chain broke and damaged the engine case near the clutch slave cylinder (see pics, please). I have noticed that the clutch does not fully disengage (bike lurches a bit going into gear, neutral is hard to find... its worse when engine is cold) ... I did not notice any leaks around this area (mineral oil or engine oil) before or during disassembly.
      The previous owner (or someone) repaired it with some sort of epoxy.
      Without doing my due diligence (checking clutch fluid level, bleeding) I hesitate to state that this is the cause of my clutch disengagement issue ... but pardon my ignorance here and help me out: How bad is this?  Am I looking at replacing my engine case here or is the previous owner's jerry rig good enough?
    • By Black Sox
      Just bought a new 2017 350 excf ,will be doing 98% off road ,ordered skid plate bark busters ,
      my ? Is what's the best easiest way to eliminate rear fender light assembly.I still would like to have a break light.
      xcf fender will fit so dealer says,under $50.00 👍But xcf brake light $125.00 .👎What's the best economical way of doing this?
    • By JNV
      Hi friends from Spain.
      Mi new KTM
    • By Brawg
      SO, for information sake and to power the search engines with some key words that i couldn't seem to trigger during my research...I'm posting my desmog process on my new 500exc. Being a new bike...i wanted to make sure that all of my "doings" were going to keep the short excuse for a warranty in tact. I have part numbers for the plugs, washers etc as well as what all came off of the bike. I know it's a simple process for some, not so for others and would like to give credit to the advrider.com writeup for some great info.
      Long story short...i plugged the hole left from the smog pump thingy on the right side of the cylinder, the Secondary Air System (SAS), the overflow canister, and all the hoses/wires that go with. The electrical plug that was involved I simply taped up with grease in it and strapped it to the inside of the frame rail.
      After i took all of it off, it would not idle....i turned up the idle adjuster (to the left) or counter clockwise in order to increase the idle speed.
      Result!!!!!! NO popping on decal, no stalling after hard accelerating, etc. Sometimes after much creeping and low rpm riding it will load up and flame out. I plan to try a different map after i install my exhaust. I think a new map will be able to add some rev to the top end. Right now it seems kind've flat once you pull through the sweet bottom and mid ranges. The bottom end power of this bike coupled with the silky smooth clutch action makes for the easiest and best suited off road bike i've ever been on. It does what i need it to do!
