Who is using an aftermarket silencer and how do you like it?
I have a friend with a 520 SX and he is planning on doing the airbox mods and getting a new silencer. He is not going for the Big Gun since they only sell the complete system.
Looking for info on Pro Circuit, FMF, Stroker or White Bros. that work with stock headpipe.
I have a Pro Circuit T4 silencer/spark arrestor. It is almost 3 pounds lighter than stock and is not obnoxiously noisy.
I really like it.
I also have the Pro Circuit T-4. It fits great, sheds some excess weight and make some serious horsepower compared to stock.
Combined with some J.D. jetting and some holes in my airbox it turned my 400 SX into a 250 eater!!!!!!!!!!
2001 KTM 400SX #529
I saw the Big Guns on John Dowd's Factory bike at the US OPEN. They are comming out with a "signature pipe" that is a copy of it...sure to be pricey...but race proven.
The T-4 is the one to get of the slip on's. I think it's a great can change it from open MOTO...Sparky...Quiet Sparky..with hand tools! I talked to several guys with'em and they all loved them.
Chris in the Mojave
'01 520 MXC
'01 200 MXC
'02 YZ250P
'01 KX85
  • Similar Content
    • By Ponch
      I have a 2007 450 EXC that I recently installed a new clutch slave cylinder on. Per the 2007 KTM service manual it clearly states that the clutch needs to be filled with hydraulic oil, which I did (magura blood). That was yesterday. I went out to double check the level today and when I removed the cover, the rubber seal was all contorted and out of shape. I then looked at the cover and it's a Brembo clutch and says "DOT 4 brake fluid only".
      I flushed the line and the master cylinder about 7 times with DOT 4 brake fluid and there was no sign of the magura blood left in the system. My question is: other than the rubber boot on the master cylinder, what damage might have been done by putting in the hydraulic oil? It was in for about 24 hours.
      Thanks in advance for any advice!
    • By pumpernickelBrad
      Hi Folks!
      Sorry if there are a bunch of threads already but I used the site's search function and didn't find anything so far...
      I just found a decent deal on a '14 350 EXC-F with 11k km (unknown hours). Has a few goodies including skid plate, hand guards and it's for sale for about $2k CAD less than a '16 with 6k km on it.
      The bike is in showroom condition (appearance) with no indication it has been offroad at all.
      What would be the gotchas that would make this deal realistic? I'm coming from a WR250R where the engine lasts forever, is 11k street kms high for these bikes?
      Are there any big defects in the '14s that I haven't dug up yet?
      With no service records what things should be done, checked, etc?
    • By Brannnt
      I purchased an '06 525 EXC some time ago, and recently pulled the motor out of the frame to address some other issues. When I removed the clutch slave cylinder, I noticed an issue the previous owner neglected to tell me about during the purchase.
      It appears that at some point, the chain broke and damaged the engine case near the clutch slave cylinder (see pics, please). I have noticed that the clutch does not fully disengage (bike lurches a bit going into gear, neutral is hard to find... its worse when engine is cold) ... I did not notice any leaks around this area (mineral oil or engine oil) before or during disassembly.
      The previous owner (or someone) repaired it with some sort of epoxy.
      Without doing my due diligence (checking clutch fluid level, bleeding) I hesitate to state that this is the cause of my clutch disengagement issue ... but pardon my ignorance here and help me out: How bad is this?  Am I looking at replacing my engine case here or is the previous owner's jerry rig good enough?
    • By Black Sox
      Just bought a new 2017 350 excf ,will be doing 98% off road ,ordered skid plate bark busters ,
      my ? Is what's the best easiest way to eliminate rear fender light assembly.I still would like to have a break light.
      xcf fender will fit so dealer says,under $50.00 👍But xcf brake light $125.00 .👎What's the best economical way of doing this?
    • By JNV
      Hi friends from Spain.
      Mi new KTM
