Riding tips for sand
I have always heard that that for riding in sand, shift as much weight as possible to the rear reducing the load on the front tire. Knowing that this 520 EXC likes to be ridden with the weight up front, I went out today and practiced riding thru the sand with my weight as far forward as I could and it seemed to improve my directional stability. Have any of you experienced the same thing? I always have a tough time in the sand, and was always told shift your weight to the rear, so any tips would be appreciated.
Here's a tip I picked up from Paul Krause at a riding clinic. In deep sand, do all your braking while still going in straight line. When you first start to lean the bike for the turn, be back on the gas. This lightens the front end much better than riding on the back of the seat and stops that tendancy of the front wheel to knife. Out here in the SoCal desert, we have plenty of sand to practice in and this tip made deep sand much easier for me.
Hope this helps.
When I was out there in CA, my 520 SX model went into the desert about an hour south/southeast of San Diego. Some sand was so deep, if you stopped, you could forget moving again....we found that out first hand. Buried up to above the axles, and NOT digging a ditch, just from sitting there!
My SX is bone stock, and I found that sitting and leaning front did make the front wheel more stable, but I also found that if I mis-read something, and hit a sand bump, or a really soft spot, or even in a turn, I would start to Jack-Knife....as I had SO MUCH weight up front, it would dig in and auger. My uncle races Fud events out there all the time (www.fudrace.com), and knows how to ride it, so I took a few lessons from him. Stand the WHOLE TIME, even in a sweeping turn if you can. Be neutral, to perhaps SLIGHTLY back. This would allow the front to float OVER soft spots, not dig in. I have never had a bike doing a 80+ mph jig under me for so long, but it WORKS!! If you stay on the gas, you will end up going straight, although you will have a bike dancing between your legs. It felt weird to me at first....I was scared to go out of 2nd gear, but I found the more back you are(within reason, not like locking your arms back...as said earlier, a fairly neutral position is sufficient), and the faster you go, the easier and more awesome it is!!
Gregg, wanna take my place here in Crapsylvania? Palm Springs is GORGEOUS!!!!! Except for that stinking wind....hate to be a bicyclist in that town!
I truly envy anyone living in that area.
[ October 29, 2001: Message edited by: Chris Slade ]
Thanks guys
I'm with Chris,
what he said works great. I ride in DEEP sand sometimes, but I have to go through trails with trees. Don't look at the trees. :)
Sand riding is a matter of giving as much gas as you can. Once you've got it, it's one of the easiest types of riding.... Gaaaasss cut, turn and WOT again.
Not very technical but rather physical.
By the way ...... I don't think I really got it :)
The followings are Steve Hatch's riding tips for sand which I got from www.dirtbikemagazine.com. I do not like to ride on sandy trails as I have to gas almost all the way out but these tips work for me well on deep sand. The points of the tips are "be on the center of bike and be aggressive".
- quote -
• Stay centered on the bike. If you’re too far forward, the front end will knife. Too far to the rear and you’ll never be able to turn. A good sand rider doesn’t use very much energy simply because he doesn’t move around on the bike that much.
• Go light on the rear brake. You don’t have to brake that hard because the sand will do it for you. As soon as you roll off the throttle, the bike will lose speed on its own.
• Steer with the rear wheel. If you wait until you’re in the turn to open the throttle, it’s too late. You actually have to start gassing it before the turn. Just grab a handful and drift the rear end around. Sand is super forgiving of too much gas. If you were that aggressive with the throttle on hardpack or in mud, you would be asking for trouble.
• Don’t worry about the ruts. Riders see sand ruts from other bikes and try to follow them exactly. It can’t be done, so don’t try. Those ruts aren’t that substantial—just plow through them and make your own.
• More throttle cures almost anything. Sand only gets nasty and unforgiving when you aren’t being aggressive.
- unquote -
Number One Tip: If you're going to ride in the sand just buy a quad. Riding your bike oin the sand makes it age in dog years! I have done it a couple of times, but never again, I want to make it last!!!
PS: I'm referring to going to the dunes, not a little sand wash here and there.
The faster you ride and the harder you hit the throttle the easier it is.
  • Similar Content
    • By Ponch
      I have a 2007 450 EXC that I recently installed a new clutch slave cylinder on. Per the 2007 KTM service manual it clearly states that the clutch needs to be filled with hydraulic oil, which I did (magura blood). That was yesterday. I went out to double check the level today and when I removed the cover, the rubber seal was all contorted and out of shape. I then looked at the cover and it's a Brembo clutch and says "DOT 4 brake fluid only".
      I flushed the line and the master cylinder about 7 times with DOT 4 brake fluid and there was no sign of the magura blood left in the system. My question is: other than the rubber boot on the master cylinder, what damage might have been done by putting in the hydraulic oil? It was in for about 24 hours.
      Thanks in advance for any advice!
    • By pumpernickelBrad
      Hi Folks!
      Sorry if there are a bunch of threads already but I used the site's search function and didn't find anything so far...
      I just found a decent deal on a '14 350 EXC-F with 11k km (unknown hours). Has a few goodies including skid plate, hand guards and it's for sale for about $2k CAD less than a '16 with 6k km on it.
      The bike is in showroom condition (appearance) with no indication it has been offroad at all.
      What would be the gotchas that would make this deal realistic? I'm coming from a WR250R where the engine lasts forever, is 11k street kms high for these bikes?
      Are there any big defects in the '14s that I haven't dug up yet?
      With no service records what things should be done, checked, etc?
    • By Brannnt
      I purchased an '06 525 EXC some time ago, and recently pulled the motor out of the frame to address some other issues. When I removed the clutch slave cylinder, I noticed an issue the previous owner neglected to tell me about during the purchase.
      It appears that at some point, the chain broke and damaged the engine case near the clutch slave cylinder (see pics, please). I have noticed that the clutch does not fully disengage (bike lurches a bit going into gear, neutral is hard to find... its worse when engine is cold) ... I did not notice any leaks around this area (mineral oil or engine oil) before or during disassembly.
      The previous owner (or someone) repaired it with some sort of epoxy.
      Without doing my due diligence (checking clutch fluid level, bleeding) I hesitate to state that this is the cause of my clutch disengagement issue ... but pardon my ignorance here and help me out: How bad is this?  Am I looking at replacing my engine case here or is the previous owner's jerry rig good enough?
    • By Black Sox
      Just bought a new 2017 350 excf ,will be doing 98% off road ,ordered skid plate bark busters ,
      my ? Is what's the best easiest way to eliminate rear fender light assembly.I still would like to have a break light.
      xcf fender will fit so dealer says,under $50.00 👍But xcf brake light $125.00 .👎What's the best economical way of doing this?
    • By JNV
      Hi friends from Spain.
      Mi new KTM
