First Oil Change
I changed the oil in my 02 400 EXC the other day. My Canadian manual says to only use Shell Advance Ultra 4. Instead I opted to use some YamyLube,and breaking the engine in for another tank. The factory oil sure didn't look like synthetic. What type of synthetic oil is everyone using? I think I'll go Mobil 1, and scott's stainless filters from here on in. Any suggestions..??
[ November 11, 2001: Message edited by: ^SQUID^ Thumper ]
I use Maxima Maxum 4 synthetic blend with great results.
You must use semi-synthetic oil until your break in is done. Then you can use full syn. oil. The brand you use is up to you. Most of the people I know use Mobil 1 or Slickolene Pro4. If you are hard on clutches and it starts to slip,switch to a semi-syn oil.
Bro, I've been playing the game of which oil is better for this and that and it all comes down to this:
For bikes, use oil that has been designed for the wet clutch type applications we see as off-roaders. Most cars oils will have detergents placed there by are friends at the EPA to reduce emmisions which are harmfull to the motorcycle clutch. Any of the oils from Yamaha, Honda, Silcoline, Maxima, Bellray, Motul, ect. will be the best bet for you.
Keep the car oils in the cars gents.
  • Similar Content
    • By Ponch
      I have a 2007 450 EXC that I recently installed a new clutch slave cylinder on. Per the 2007 KTM service manual it clearly states that the clutch needs to be filled with hydraulic oil, which I did (magura blood). That was yesterday. I went out to double check the level today and when I removed the cover, the rubber seal was all contorted and out of shape. I then looked at the cover and it's a Brembo clutch and says "DOT 4 brake fluid only".
      I flushed the line and the master cylinder about 7 times with DOT 4 brake fluid and there was no sign of the magura blood left in the system. My question is: other than the rubber boot on the master cylinder, what damage might have been done by putting in the hydraulic oil? It was in for about 24 hours.
      Thanks in advance for any advice!
    • By pumpernickelBrad
      Hi Folks!
      Sorry if there are a bunch of threads already but I used the site's search function and didn't find anything so far...
      I just found a decent deal on a '14 350 EXC-F with 11k km (unknown hours). Has a few goodies including skid plate, hand guards and it's for sale for about $2k CAD less than a '16 with 6k km on it.
      The bike is in showroom condition (appearance) with no indication it has been offroad at all.
      What would be the gotchas that would make this deal realistic? I'm coming from a WR250R where the engine lasts forever, is 11k street kms high for these bikes?
      Are there any big defects in the '14s that I haven't dug up yet?
      With no service records what things should be done, checked, etc?
    • By Brannnt
      I purchased an '06 525 EXC some time ago, and recently pulled the motor out of the frame to address some other issues. When I removed the clutch slave cylinder, I noticed an issue the previous owner neglected to tell me about during the purchase.
      It appears that at some point, the chain broke and damaged the engine case near the clutch slave cylinder (see pics, please). I have noticed that the clutch does not fully disengage (bike lurches a bit going into gear, neutral is hard to find... its worse when engine is cold) ... I did not notice any leaks around this area (mineral oil or engine oil) before or during disassembly.
      The previous owner (or someone) repaired it with some sort of epoxy.
      Without doing my due diligence (checking clutch fluid level, bleeding) I hesitate to state that this is the cause of my clutch disengagement issue ... but pardon my ignorance here and help me out: How bad is this?  Am I looking at replacing my engine case here or is the previous owner's jerry rig good enough?
    • By Black Sox
      Just bought a new 2017 350 excf ,will be doing 98% off road ,ordered skid plate bark busters ,
      my ? Is what's the best easiest way to eliminate rear fender light assembly.I still would like to have a break light.
      xcf fender will fit so dealer says,under $50.00 👍But xcf brake light $125.00 .👎What's the best economical way of doing this?
    • By JNV
      Hi friends from Spain.
      Mi new KTM
