250f vs. 450f
I was wondering which of the four stroke bikes is the most reliable, i have a 250f now and seem to be doing alot of maintenance (valves, shims, plugs, pistons)...can you run a 450f longer before doing the valves, etc. on it or are they pretty much the same, basically will a 450f last longer than a 250f? :banghead:
well, no.🤣
but, if your a "pro" rider, in the long run the 450F might have it easier, becuase of its power i don't think i would need to rev it as much. so if i got a 450, it would go longer between valves shims. :applause: i don't mean to sound big headed, but i'm always revin' my 250F pretty high, with a 450F it would be different.
Your exactly right way fast whitley, ive raced a 250f for ever and they dont seem to last as long between valve adjustments then the 450 does. i love my crf450 now its all the power i need and some but not overly fast where you cant control it.
