digitaldan Posted September 19, 2005 I just read this article on ADVrider http://www.advrider.com/forums/showthread.php?t=71159 Then I started to wonder if one could install a "sight tube" on a DRZ as well ? I mean it also uses the dry sump setup with the oil in the frame. I would be a bit hesitant to drill holes in my frame but it could be done right ? Share this post Link to post Share on other sites
Erik Marquez My Rides (5) Posted September 19, 2005 I just read this article on ADVrider http://www.advrider.com/forums/showthread.php?t=71159 Then I started to wonder if one could install a "sight tube" on a DRZ as well ? I mean it also uses the dry sump setup with the oil in the frame. I would be a bit hesitant to drill holes in my frame but it could be done right ? Something else to break..fail.. cause a DNF... Check your oil pre ride.. get in the habit of paying attention to your bike during a ride,, You'll know if it's leaking oil.. if so,, check the level. Change it often,,, oil comes out,, 2 qt goes in., you know the level Share this post Link to post Share on other sites
