Electric start...
http://www.thumpertalk.com/forum/search.php?searchid=679158
You will find several threads on the subject using the seach feature.
Very expensive, not worth it. Basically same as for YZ450F:
1825519-001 MOTOR ASSY
2003 Yamaha WR450FR STARTING MOTOR $253.00
1825463-001 COVER, CRANKCASE 1
2003 Yamaha WR450FR CRANKCASE COVER 1 $96.10
1829038-001 COVER 2
2003 Yamaha WR450FR CRANKCASE COVER 1 $24.17
1825465-001 GEAR, IDLER 1
2003 Yamaha WR450FR STARTER CLUTCH $59.95
360156-001 BEARING,CYL.#10
2003 Yamaha WR450FR STARTER CLUTCH $11.14
47708-001 SHAFT 1
2003 Yamaha WR450FR STARTER CLUTCH $6.30
1825467-001 GEAR, IDLER 2
2003 Yamaha WR450FR STARTER CLUTCH $30.87
1825466-001 GEAR 3
2003 Yamaha WR450FR STARTER CLUTCH $60.82
347415-001 WASHER,PLATE
2003 Yamaha WR450FR STARTER CLUTCH $4.54
1828086-001 BEARING
2003 Yamaha WR450FR STARTER CLUTCH $13.61
1825468-001 STARTER ONE-WAY AS
2003 Yamaha WR450FR STARTER CLUTCH $68.94
734-001 BOLT
2003 Yamaha WR450FR STARTER CLUTCH $0.50
1825539-001 C.D.I. UNIT ASSY
2003 Yamaha WR450FR ELECTRICAL 1 $246.83
1825540-001 BAND
2003 Yamaha WR450FR ELECTRICAL 1 $3.83
1745408-001 IGNITION COIL ASSY
2003 Yamaha WR450FR ELECTRICAL 1 $73.89
1825528-001 NEUTRAL SWITCH ASS
2003 Yamaha WR450FR ELECTRICAL 1 $38.03
1394-001 BOLT,SOCKET
2003 Yamaha WR450FR ELECTRICAL 1 $0.42
353121-001 CLAMP
2003 Yamaha WR450FR ELECTRICAL 1 $1.57
13467-001 BAND
2003 Yamaha WR450FR ELECTRICAL 1 $1.65
301958-001 CLAMP 1
2003 Yamaha WR450FR ELECTRICAL 1 $1.15
353161-001 CLAMP
2003 Yamaha WR450FR ELECTRICAL 1 $1.17
1825529-001 WIRE HARNESS ASSY
2003 Yamaha WR450FR ELECTRICAL 1 $108.00
1825524-001 DIODE ASSY
2003 Yamaha WR450FR ELECTRICAL 1 $5.58
287915-001 DIODE ASSY
2003 Yamaha WR450FR ELECTRICAL 1 $6.19
1825523-001 RECTIFIER & REGULA
2003 Yamaha WR450FR ELECTRICAL 1 $66.27
1825480-001 BRACKET, REGULATOR
2003 Yamaha WR450FR ELECTRICAL 1 $2.54
795-001 BOLT,FLANGE(4MY)
2003 Yamaha WR450FR ELECTRICAL 1 $0.65
939247-001 CLAMP(MG5)
2003 Yamaha WR450FR ELECTRICAL 1 $1.78
2518468-001 YTZ7S HE YUASA BAT
2003 Yamaha WR450FR ELECTRICAL 1 $79.95
337034-001 BAND, BATTERY
2003 Yamaha WR450FR ELECTRICAL 1 $3.97
1825525-001 WIRE, PLUS LEAD
2003 Yamaha WR450FR ELECTRICAL 1 $7.62
1825520-001 STARTER RELAY ASSY
2003 Yamaha WR450FR ELECTRICAL 1 $38.40
42362-001 FUSE (10A-BL)
2003 Yamaha WR450FR ELECTRICAL 1 $0.96
1825350-001 COVER, LEAD WIRE
2003 Yamaha WR450FR ELECTRICAL 1 $1.71
4654-001 BOLT,SMALL FLANGE
2003 Yamaha WR450FR ELECTRICAL 1 $0.32
1825521-001 HOLDER, RELAY
2003 Yamaha WR450FR ELECTRICAL 1 $6.29
938751-001 RELAY ASSY
2003 Yamaha WR450FR ELECTRICAL 1$12.83
1825527-001 MAIN SWITCH ASSY
2003 Yamaha WR450FR ELECTRICAL 1 $68.27
2521134-001 STAY, MAIN SWITCH
2003 Yamaha WR450FR ELECTRICAL 1 $5.83
1825515-001 STATOR ASSY
2003 Yamaha WR450FR GENERATOR $106.67
1825516-001 ROTOR ASSY
2003 Yamaha WR450FR GENERATOR $162.33
$162.33
Sub-Total: $1,625.56
Is it worth it
You left out the fact that in order to use any of the parts you listed on a YZ 450, you first need to replace the crankcases, about $500. the YZ cases will not accept the starter motor, or the WR ignition cover, and has no bore to support the idler gear pin.
Furthermore, the starter clutch must be mounted to a WR flywheel, which will not mount to the left axle of a YZ crank.
Minor annoyances, I'm sure.
I have heard of kits that sell for $800 or so, but I wouldn't know where to look for them.
The best way to get an electric start is to buy a WR450 and mod it into something more like the YZ. It's a whole lot less expensive.
