Hotcam Intake w/o FCR
Will the CV carb on my S be Ok w/a hotcam intake?
The FCR swap is expensive....
If you want more bottom end and mid-range and have it jetted properly then yes a hot cams intake will work fine. Do yourself a favor and go with the stage 2 :banghead:
Do i need to do a FCR swap if i use both stage 2 intake & exhuast for 05sm?
I'm running the CV and the Stage 2 Hotcam intake. It will work just fine :banghead:
yes. I have it. Good boost in grunt and growl but not up top. Need exhaust cam for that. 36mm cv carb should be able to feed 50 horses but will not have the low speed lunge of the fcr pumper carb and will feel lazy on top due to the high velocity of the air stream but the numbers will reveal the truth. Of course, if you're riding it, rather than reading it, numbers don't mean jack____.
