Front Break Pads Rub on Rotor when Spinning Front Wheel
When my bike is up on the stand and I spin the front wheel there is a rubbing sound on the disc from the break pads. The sound is slightly pulsating, but the rotor is not bent or off true. I took off the caliper and there is ZERO noise when spinning the wheel so it is not the wheel bearings. This somewhat normal? Any ideas? Pads Low?
It supposed to.. Its normal. disc brakes are designed to drag a bit..
yes sir that be true. I got the same here. seems fine to me.
