Aftermarket bottom triple clamp for TTR125?
I did some searches but haven't seen this get discussed. Is anyone aware of an aftermarket (better than stock) bottom triple clamp for TTR125's? Last time I put the forks on it, one of the bottom clamp bolts felt weird when I torqued it down. I always use a torque wrench, but I'm afraid there might not be a lot of life left in the stock one. If I have to replace it, I'd rather get something a little stouter than the stock piece.
Thanks!
Kelly
Why not just replace the bolt for $1? The weird feeling you felt is not likely due to the clamp, but rather from the bolt.
Since the bolt is steel and the clamp is aluminum, if anything is distorting, it's the triple clamp, although I think the distortion has caused the bolt to bend slightly.
Thanks for everyone's input. I'll probably end up getting a stock piece if it give up on me. TTR125, I'll contact you if I end up needing one.
