Jingle Posted September 23, 2005 I was waiting for this day, but hoping it would never come. Well i wasnt revving my bike that hard. I was in third gear and i hit a jump. Right when I left the ground i heard a crack and i thought my chain broke. But i hit the ground going so i pulled off. I heard my engine ticking very bad. I rode to my truck and my friends dad was waiting there and he said it sounded like i threw a bearing in my bottom end. But i thought if it was a bearing it would lock up and not click. I hope its vavles but im not sure at all. any help would be great. and if it is valves like i think what are some good aftermarket ones and what else should i replace? springs? Share this post Link to post Share on other sites
Jingle Posted September 23, 2005 o i forgot well it started up pretty easy after i shut it off. Thats the only thing that makes me think it isnt the valves. Share this post Link to post Share on other sites
MXER43 Posted September 23, 2005 Might be a broken bucket, it will run but make a clanking noise. If you continue to ride it you will destroy the cam lobes (if they are not already damaged) and risk the chance of breaking a valve. Pop the lid and you can see the buckets. This is pretty common issue. Good luck let us know what you find. Share this post Link to post Share on other sites
Jingle Posted September 23, 2005 thanks for the reply what bucket are you talking about? is it the cam bucket? what the cam sits in? i hope that is what it is. I hope it wasnt my bottom end. Share this post Link to post Share on other sites
ochster Posted September 23, 2005 The term "bucket" is sorta of industry slang, the actual part is a "tappet". There is four of them on these bikes, one below eack cam lobe that sits over each valve stem/spring. The shim that you remove/replace to adjust your valve clearance is under the each tappet on top of the valve stem. Share this post Link to post Share on other sites
letmein Posted September 23, 2005 It sounds to me like you are not a mechanic. So do one of two things; take it in and have it looked at; or have a friend who is very good working on engines help YOU tear it a part until you find the problem. You will learn a lot by observing someone who knows what they are doing. But, do not ride it until you are sure you have fixed the problem. Share this post Link to post Share on other sites
Jingle Posted September 23, 2005 nah ur dead right. Im not a mechanic but i am competent enough to do some engine work. That is the only thing i have never done is a four stroke engine. Ive put many top ends on 2 strokes. Im only 17 but have been riding and racing for about 5 years and i have never had to take my bike to a shop but the zuk looks like it will be heading there. i drained the oil and no shavings or anything so thats good news. Share this post Link to post Share on other sites
Suz459 Posted September 23, 2005 Hey Jingle If you have the manual (and if not you can do a search and download it) none of this is very hard, the main difference between the 4-stoke and the 2-stroke is the valve train the tolerances are very tight and some things really need a trained eye to see but you can always take just that part to a qualified shop, and remember just because they sell bike's doesn't mean their mechanics know what there doing, if you race I'm sure there's people at the track that can point you to somebody that knows what there talking about. So tear into it and tell us what you find, thats the only way to figure out the 4-stroke. Just my 2 cent's. Share this post Link to post Share on other sites
Jingle Posted September 24, 2005 well i didnt tear into but i did solve the problem. Went down to the honda shop and traded it in on a 03 450 with proaction suspension and a fmf titanium 4 system on it. I gave them my bike and 650 bucks. A good deal in my book. thanks for the help guys. Share this post Link to post Share on other sites
