Jimmy Pang Posted September 26, 2005 i've got a thumpstar 120cc........ does any one know how to connect a rev counter on...... i think it connects up to the ignition but im not sure. Share this post Link to post Share on other sites
aedwards07 Posted September 26, 2005 Kitaco makes one. Share this post Link to post Share on other sites
Jimmy Pang Posted September 26, 2005 i've got the rec counter, but im sure how to wire it up Share this post Link to post Share on other sites
Gutty Posted September 26, 2005 Assuming it's the same as a go-kart taco, hook one wire up to earth, and the other up to your sparky lead. Share this post Link to post Share on other sites
Jimmy Pang Posted September 26, 2005 cheers mate, i'll give that a go. Share this post Link to post Share on other sites
woodsrat Posted September 26, 2005 I use a mini tach that's available in the US for around 40 dollars on my XR-650L--uses it's own non-replaceable battery (a throwaway unit, supposed to last five years) and it also keeps track of the number of hours run. One wire hookup, too--just wrap a wire around the plug wire a few turns and then push the wire into the tach/hourmeter's groove. Definitely worth the bucks and simple to install. Share this post Link to post Share on other sites
Jetster220 Posted September 26, 2005 Hey woodsrat, where did you purchase it at. Share this post Link to post Share on other sites
woodsrat Posted September 26, 2005 A place in Maryland called Jack's Small Engines although you can get them from lawn mower shops. Share this post Link to post Share on other sites
ben_suhard Posted September 30, 2005 ENM have a 50% off deal if you order three or more. http://www.enmco.com/ Share this post Link to post Share on other sites
mattv Posted October 1, 2005 so who else wants one? http://www2.catalognavigator.com/enmco/item/enm-counting-instruments-tach-hour-meters/powered-engine-digital-tach-maintenance-hour-meter/pt141?&plpver=1001&origin=viewitems&by=prod&assetid=spec&filter=0 Share this post Link to post Share on other sites
Kurlon Posted October 2, 2005 Note, the update speed on these things isn't exactly snappy. They are made to monitor tractors, where you set one speed and leave it there. I think the update rate is once every half a second, or once a second? Share this post Link to post Share on other sites
Jimmy Pang Posted October 2, 2005 yeah that is true..... the rpm is update every 2 seconds.......... Share this post Link to post Share on other sites
