metal shavings in engine what do i do??
i was riding my 05 crf250 and it was riding fine washed it cleaned it up and stored then the starting got harder and harder so i replaced the shims. After about 3 weeks of riding 5 hours a week it got hard to start again, so i started to push start it and was riding at a practice when all of a sudden the bike seized up and wouldnt budge so put it in nuetral and rode my dads bike for the rest of the day
then i got home and took it apart and found billions of metal/bronze shavings all over in my filter and on the bottom of my engine and the pistonrod bearings suck. The bike is only 5 months old and has less then a 100 hours on it
someone please help
i figured out what is wrong and finnaly got it put back to gether and the bearing in the crankshaft fellout and got al ground up i have no idea what or why this happend so i am going to start it up tommorow and see how it run and i did all the work myself which saved me a total of like 2-3000 bucks and some of the other bearings in the engine were shot to so ill post what the results are for the final product later
first of all, i cannot believe that you were riding this thing knowing that there was a problem since it would only start by "pop-starting" it. sounds like you need new valves..... and definately watch your oil and keep a good filter in there to clean the system of the shavings !!! goodluck !!
all this and the bike is how old? how often do you change oil and what do you use?
