1990 LC4 600 shift shaft seal
Hello,
Anyone ever replace this monkey? I've got the seal. I've got the engine diagram pdf's. I've got the shift lever and the kickstart lever removed but can't see anyway aside from splitting the case to get this thing in... Any help would be appreciated.
Thanks,
Spanky
hello i have an 620 exc 1994, i think maybe the procedure for change the seal is the same, first drain all the oil from the engine then i took off the old seal , and then clean the hole with a cleaner (not too much quantity and carefully not to spurr cleaner inside of the engine) then put some glycerine wax or simply a little oil in the interior of the new seal (for lubrication and preventing damage on the replace) then i put a very little quantity of silicone on the exterior border of the seal, with a lot of patience put the new seal on place ( i made a my own tool for this operation with a small bar of hard wood and a small hammer) be very carefull about the position of the new seal going in to the case. i hope this helps
bye
