Getting rid of surge?
I have a 2002 VOR 530 sme with the Delorto 39mm Flatside. I have just had it rejetted and dyno'ed, though I don't have much trust in the place i took it.
On the dyno graph it show that the mixture is perfect however there is a noticable surge early in the rev range when accelerating and at constant throttle.
the idle is generally ok although it does sometime cut out if the the throttle is close at traffic lights.
the surge occurs in the first 10% of the throttle then it is fine.
Also when you say increase the needle 1 clip what does that mean exactly?
thanks for your help
ok,sounds as if the idle is may be lean as well.try opening the fuel screw a 1/2 turn as well.
when i say raise the needle 1 clip i mean lower the clip one position.
lowering the clip postion raises the needle.
