YTZ10S Battery
Sounds like a great improvement but I think you will have a problem fitting it to a DRZ.
Make a dummy out of wood and see what it takes to fit it in place.
Its only slightly bigger 7/8th of an inch so should be any problems getting it in
DRZ400 Yuasa Battery
Battery Type: YT7B-BS Dimensions: 6" x 2 9/16" x 3 11/16"
(Like this verbage on the yuasa website for the DRZ....)
*Due to a constant current drain on vehicle, this battery should be maintained on an automatic charger whenever vehicle is not in use.
YTZ10S Dimensions: 6" x 3 7/16" x 3 11/16"
Might be able to make up that 7/8" by removing the padding in the battery holder????
Think I rather have the padding... I have no problems with my battery...
