What right for me xr 250 or 400
Im 80kg 178cm tall and 15yrs old i ride a fair bit of single trail.
I have got a xr100 witch is floged out to the max. Here in austalia the xr400s are more common and maybe a bit cheaper.
I know someone selling a xr250 02 modlel with on 300kms like new for 4500aus dollars do you think its worth it. Is the sixth gear on the 250 mainly for the road or do you use in the bush to ?
So 176 lbs, 5'-10", and 15 years old; the 250 would sure be an easier transition from the 100 but at 5'-10" you should not have much problem with the 400 either. The 5th and 6th gears are usually just for very easy roads unless you ride like Scott Summers.
Thanks well i think iam only going to get taller because both my brothers are 6' 2 and 6' 4.
Well the extra gear better not be for the bush or you might be going a little fast :banghead:
