04 Husky SMR450 Rear Wheel Options
So I found out the rear wheel on my tard is cracked, bent and should be replaced. Are there any aftermarket wheel sets that will pretty much bolt on or do I have to go with a stock replacement?
New stock rim is about $300 plus labor to get it laced, but I'd rather just go aftermarket and it may even cost less.
If Marchesini has a set that will work I would probably even go for those!
What should/can I do? Anyone have a good spare rear rim/wheel that I can buy?
HEEELP! Thanks
Talon makes hubs, but most U.S. distributors don't carry them. You can buy them direct from the UK, but it's going to cost you. Check out the stuff at Go-faster Supermoto store as they have hubs to fit your bike.
You might also want to talk to Yorkshirepud as he seems to have aftermarket hubs and rims on his '04 TE450.
I have a brand new Eddie Seel 5" blue rear rim made by Reflexegen & also have the front in blue a shade lighter blue.
These fit the Husky hubs & are drilled ready.I am based her in the UK.PM if interested. £130 rear £85 front
