'05 crf450- popping
Just bought a '05 crf450 that "pops" right off idle and when coming into corners. I'm in florida and its around 90, sea level. Guys on the 450 thread said its is probaly lean or could be clogged pilot. I was planning on giving it a little more on the fuel screw, thought i would check here also. Thanks!
my o4 crf 450 was lean out of the box(sealevel 26deg celcious) but not enough to pop.
some fuels can vary between brands enough to make a bike lean or rich to.
but check your hot start is not slightley blocked open or out of adjustment.
and also you havent lost your fuel mixture screw.
Burned: I didn't think about it at the time, but yeah i would say with the throttle totally shut. Mostly coming into corners right before i get back on the gas.
Note: this was the very first time i rode the bike, have not played with it yet.
- forgot that i did notice the Dr.d hot start did have a little slop in the lever-thought that might have something to do with it- was going to adjust that first
-if that didn't work i was going to give more with the fuel screw
is this right? thanks!
