Is it okay to put a ziptie on the shock shaft
Is it okay to put a ziptie on the shock shaft to see how much travel in the rear I am using? I have had a ziptie on the forks for awhile but I want to make sure it is okay to put it on the shock shaft.
The marks under the rear fender is always a good sign of full travel.
maybe you can see how much of the crome on the shock that is clean, but that ofcourse only if working with "maybe" not enough travel, help it a little with spraying a light silicone spray on the crome and check afterwards. It's much better in dusty conditions. :banghead:
