WR 250 Gas
I get about 45 mpg dual sporting mine and keeping at at low revs--say about 4,000 rpm in 5th just putting on back roads around 30mph.
I can go about 90 to 100 miles on single track and ORV trails, with a bit of road.
I can't ride at the rev limiter very often--too scary! But I can tell you it uses a lot more gas.
I have a large Clarke tank on my WR. I tried a YZ tank on it one time--I ran out of gas. I sold the tank.
It all depends on where and how your ride. You should be able to get at least 80 miles no problem with a lot of hard riding.
on my 04' stock tank. I've never ran it out, but last I checked I was right around 75mi, but that was with semi-hard riding. Cruising thru trails at low revs? who knows? 100mi, maybe.
Edit: also note that jetting will play an important role in mileage. How much? I don't know, I don't have those kinds of facts :banghead:. But no doubt, a properly jetted bike should get far better mileage than one poorly jetted.
If you still have the factory throttle stop in :applause: you might get 300mi to a tank!!! 🤣
Joe
The gas milage is always relative to trail conditions. I have the 2.5 gallon tank on my wr250 (2003). I have run out of gas at 52 miles and went over 90 miles on one tank.
Now that it is broke in and with a 12 tooth front sproket, I can count on 80 miles per tank on an AVERAGE...............that is 32 mpg...
I most always single track trail ride...
PS...at 57 years old after 80 miles I'm glad to load it up............
I get about 50 mpg when riding on a ride that will take me over 100 miles... If the ride is shorter I tend to use more gas per mile cause I know I can last at higher intensity.
If you've got 90 miles to ride between gas stops it can be done on about 2 gallons-
It also depends in wether your bike is running properly. I burn more gas when my jetting's off-
Adam
