harjp1959 Posted September 29, 2005 The Kientech Extended Fuel Screw I had in my carb popped out while riding. Found the screw, spring and o-ring sitting in the engine. No washer though. I hope I can find a washer that fits at Ace. Why would this happen? (Assuming I didn't turn the screw out too far.) Share this post Link to post Share on other sites
harjp1959 Posted September 29, 2005 (need to get this thread on 1st page) Share this post Link to post Share on other sites
Neil Claydon My Ride Posted September 29, 2005 (need to get this thread on 1st page) Why🤣 -------------------------------------------------------------------- If you did not unscrew it to far, then it can only be vibration. My extended fuel screw never moved, even when 4 turns out. If it continues to be a problem, I would drill it and wire it. Neil. 🤣 Share this post Link to post Share on other sites
miken Posted September 29, 2005 Maybe try stretching the spring a little to put some additional tension on the threads and prevent it turning out? Mike - Share this post Link to post Share on other sites
palys2 Posted September 29, 2005 I put two O-Rings on mine to add a little more pressure and keep it from backing out. Share this post Link to post Share on other sites
harjp1959 Posted September 29, 2005 Thanks guys! By the way, I found the washer on the garage floor this morning. I probably turned the damn thing out way too far..... Share this post Link to post Share on other sites
HondaJ Posted September 30, 2005 I had the same thing happen, except I did not find the screw and it was only 3.5 turns out. It was my second ride with the 3X3 and full Yosh and re-jet. The first ride I got a flat tire. I don't know if I will ever get to ride this thing! But it ran real strong until it fell out. Just placed my order for another assembly. Is this a common problem with the extended screw? Share this post Link to post Share on other sites
JoelH. Posted September 30, 2005 People here didn't seem to think much of the idea. But I safeguarded my pilot screw with large shrink tubing slipped up over the screw and boss. At this point it can still be adjusted because while it grabs the knurling on the screw well, it still will turn on the boss. Because I don't seem to need to adjust it I then put a dab of RTV on the tubing/boss junction and it's bulletproof. FWIW Share this post Link to post Share on other sites
harjp1959 Posted September 30, 2005 Well, the fuel screw is back in. Rode about 30 miles tonight. Checked it about 100 times mid-ride. Still there. Bike runs much better with fuel screw in place! Share this post Link to post Share on other sites
drjack Posted September 30, 2005 I had the same thing happen, except I did not find the screw and it was only 3.5 turns out. It was my second ride with the 3X3 and full Yosh and re-jet. The first ride I got a flat tire. I don't know if I will ever get to ride this thing! But it ran real strong until it fell out. Just placed my order for another assembly. Is this a common problem with the extended screw? It doesn't seem to be a common problem, but it does happen. The weight of the extended screw coupled with the vibration can cause it to fall out. It's more likely if the screw is turned way out, trying to compensate for the wrong PJ. Share this post Link to post Share on other sites
HondaJ Posted October 1, 2005 Thanks guys. There are some good ideas here. Share this post Link to post Share on other sites
mgordon Posted October 1, 2005 The Kientech Extended Fuel Screw I had in my carb popped out while riding. Found the screw, spring and o-ring sitting in the engine. No washer though. I hope I can find a washer that fits at Ace. Why would this happen? (Assuming I didn't turn the screw out too far.) happened to me twice, will have to read up on this problem to see what can be done to fix this. Share this post Link to post Share on other sites
MIGHTYMOUS327 Posted October 3, 2005 Yes. I Put The Original Screw Back In And Tightened It All The Way. The Bikes Runs Ok If You Know How To Work The Throttle. Share this post Link to post Share on other sites
