450 R air filter install ( piece of cake )
I found the easiest way to put the air filter back in. I usually dont have much trouble with it but the other day it was taking a long time to line up the screw. I run both the Twin Air and an OEM filter. Here is the procedure it is very basic and easy.
1) Place filter in airbox and rotate until arrows are lined up
2) Peel back the airfilter at the top ( off the cage ) about 1 inch to expose the inside so that you can see the threads on wing nut line up with the threaded hole
3) Now peel the filter back on the cage at the top and make sure you have it sealed
4) Tighten nut and then run your hand around filter to make sure it is seated all the way around.
