Boysen quickshot for a crf250r
I checked the search could not find a thread. Could you tell me if this mod is worth the money. I have not piped it and the only thing done is jetting.
My buddy put one on his 250X and we didn't notice anything different. I would say probably not.
It will work wonders on the CRF250R if you go w/the aforementioned Leak Jet. Call Boyesen's 800-441-1177 to be sure if the 55 is the way to go.
Regarding the CRF450, it doesn't much difference. I ran one w/a JD jet kit on my '04 and it worked a little better w/the FS turned out 1/4-1/2 from where I had it. I have it on my new '06 w/the stock jetting and it helped a little.
Bottom line if you ride a CRF250R I would reccomend, you can go without on the 450R.
I searched and found alot of threads about this.
It seems that if you put a 55 leak jet, you'll get the same effect for less money.
Here's what I found. On my 250 it got rid of the bog and improved off idle
response. When I ride my 450 in tight woods it will not stall and off idle
response is too good. It doesn't bog, but it makes the 450 come to attention a
little too aggressively in the tight stuff.
49 state models come with a 55 leak. CA model doesn't.
That's on the X.
The R comes w/ a 70.
