chinese engines with Takegawa / Kitaco parts
it would be intersting to see if the gearbox would take it as they are renowned for 3rd to go as stock although mine has been fine.tbh though you could probly find a second hand honda motor with a similar kit for around the same price.
If you did it I highly wouldnt recomend using the stock chinese 4speed, IT WILL BREAK, you would need to upgrade with the close ratio 3spd and clutch from either Takegawa or Kitaco.
so is that a yes to my question then....... Takegawa / Kitaco parts are compatible with Chinese engines?
depends on the motor,
:banghead:
In your case i believe the kitaco parts will fit......but that doesn't mean they'll fit all chinese engines. :banghead:
