farmerj Posted October 1, 2005 I wanted to try the EMM needle (with 38 pilot, 158 main, PAS @5/8) but Sudco doesn't have any until the end of October. They suggest EMN as the closest replacement. Will the EMN work? Thanks, Jeff Share this post Link to post Share on other sites
Wayward Son Posted October 1, 2005 yes,it will work fine.slightly leaner at small throttle openings. what pipe and air filter?you will probably need smaller main jets......... Share this post Link to post Share on other sites
farmerj Posted October 1, 2005 Burned, Thanks for the reply. Stock pipe, stock filter w/snorkel removed (current jetting - 45 pilot, 2.5 air screw, 160 main, stock needle + taffy mod). ..."slightly leaner at small throttle openings." I'm trying to get rid of the "off-idle bog" and low speed stalling, so I'm not sure that I want things "leaner" off-idle - but with your encouragement, I'll give it a try! "you will probably need smaller main jets........." I think I've read that you recommend 150-155?? I'll try that! I sure appreciate your response! Jeff PS - Would EKP be a better needle choice than EMN? Share this post Link to post Share on other sites
Wayward Son Posted October 2, 2005 its leaner than EMM not the stock DXP.its richer than the DXP.EKP will be the same as stock at small throttle openings. Share this post Link to post Share on other sites
