Any jetting change required for E cam?
Hi burned,
The jetting specs you gave me for the FCR on my '05 DRZ S model worked great. I've leaned it down a bit (dropped from the 155 mj to a 152, and eventually settled on a 150, and dropped the pilot from a 38 to a 35, and raised the needle clip from #3 to #2, fuel screw as needed-usually about 2-3/4 to 3 turns) as a compromise setting to cover the range of elevation that I typically ride, but other than that it's just as you spec'd, which was:
155 main jet
200 main air jet
emm needle
clip 3
38 pilot jet
5/8 turn pas
2 turns fuel screw
this is with the coast enrichner removed.
Since I don't expect you to remember every bike that you've been asked about, the rest of my set up is:
Yosh SS full system
3x3 airbox hole (actually more like 4x2.25, but you know what I mean)
E base gasket
Hotcams stage 2 intake cam
OEM '03 E model FCR with TPS plugged in.
I'm going to change to the E model exhaust cam (I have the brand new cam sitting right here on my desk) and I was just wondering if I should anticipate having to make any jetting change(s) to accomodate it.
Thank you.
Based on the above..................
2005 DRZS at sea level
TT FCR MX
Yoshi Ti w/spark arrestor in
3X3
Hotcams StII intake
Don't get excited about the cam, jet per standard reccomendations.
TT FCR MX
3X3
Hotcams StII intake
what are you asking?
If I start with a 2005 DRZS at sea level and install the TT FCR MX with ................
- 200 Main Air Jet
- 155 Main Jet
- 45 Pilot Jet
- 100 Pilot Air Jet (removed)
-EMN needle, third slot from top
....................and also have....................
Yoshi Ti w/spark arrestor in and the 3X3 mod, adding the Hotcams StII intake will not change the main jet requirements (much if at all).
Is this right?
Thanks!
