help with cam and chain!!-
hi i just got my trail biek big bore in the mail, i am almost finished installing it all i need to do is set the valves and install the cam and cam chain. this is the problem , when i install the cam gear how do i get the chain on? do i put the chain on before i bolt down the cam gear?
put the cam in the head, make the lobes point to the piston (the lifters not touching the cam lobes.)
put the sprocket on the chain and use a screwdriver to slowly pry it on.
set the gap between the lifter and valve to .003"(exaust and intake)
