Handguard question...
Hi all. Could somebody edu-macate🤣 me please?
I just put on a set of aluminum bars and found out I need different adapters for those than my old steel bars :banghead:🤣 .
Anywho...it got me thinking...what brand of hanguards are those with the bend on the side for easy hand access and that also mount to the triple clamps? I can't recall.
Also...does anyone know if there's an adapter for Moose handguards to mount them to the triple clamps instead of clamping on to the bars?
Thanks :applause:
Cycra are the handguards you are thinking of. Acerbis is now making a similar setup. I have not seen a kit to make other handguards mount like cycras but i'd bet you could buy the cycra triple clam brackets and bend you mooses to fit.
I tried out my new cycras this weekend. the made it through some stuff i know would have bend my old tusks.
I just put on a set of aluminum bars and found out I need different adapters for those than my old steel bars :applause:🤣 .
Thanks 🤣
If you mean the fittings that go in the end off the H/bars have a look at this .
Hope it helps.
Neil. :banghead:🤣🤣
