ASTAR Posted October 2, 2005 Ok, so i was in the process of woring up my new LED brakelight. I test to see which wire was the brakelight and got a signal with brake lever pulled. Hooked everything up and now it doesn't work. I took it all apart again and tested the wire again with test light and got nothing. Is there some sort of fuse or something for the brakelight? I do have head and tail lights... HELP!!! Share this post Link to post Share on other sites
Noppy Posted October 2, 2005 Look if you didn't engage your brake switches continuously. Because then you wouldn't see the difference between on and off, but your brakeswitch is working (too good). Also check wheather your front brake switch is not activated by accident (Murphey's law). Noppy Share this post Link to post Share on other sites
ASTAR Posted October 2, 2005 Hey, thanks for the reply, i was testing the wrong wires! I'm an idiot Share this post Link to post Share on other sites
