break rotor
I might try that the one that was on it was bent soo bad i could not bend it back, it was like a waffle.. I put a slightly bent one from my 250 on it and I was out at the track sunday and the back breaks sucked soo bad..
Spend so time with a cresent wrench...Ive straightend mine a couple times, but it takes some patients...
You need patients to straighten out your rotor? Where do you get them? At the hospital? :banghead:
I straighten mine the same way, with a crescent wrench.
Those Rocky mtn. rotors work great.
I second that.
BTW, dont lay your rim on the ground, rotor side down, then accidentally step on it, the rotors dont like that........... :banghead:
