where is the air/fuel screw?
underneath the carb pointing straight up. the problem is it is sealed with a plug from the factory so you have to remove the carb and pull the plug out. if you are going to go that far it would be a wise investment to install a Dynojet kit, "Burned jetting", and the 3x3 airbox mod.
