TTR 125 / Front End Conversion Questions.
1. Where is a good place to mount the choke?
2. Will the YZ front brake line work on the TTR.
3. Front fender, did you use the stock TTR or did u buy a YZ fender.
Dont say goto the TTR125L.com site, he has very basic limited information.
Has anyone replaced a seal before on the front fork?
Maybe modify your existing chock bracket.
YZ brake line will work if you use the YZ master cylinder.
I just bought the YZ fender but you can re drill the TTR.
Replacing the seals will be easy for you also.
Seal driver (To drive in new seal,made mine out of a chunk of PVC pipe)
Screwymadriver (To pull dust cover and retaining ring out)
Hammdammer (used to tap on your new seal driving tool that you just made)
Needle nose pliers (Maybe to help your screwymadriver out during the process stated above)
And maybe some other tools laying around so if someone comes in it will look like your doing something Important.
