help with valve adjustment. feeler guage? help!!
im installing a 88cc tb big bore and im done only thing i got left is the valves. i got a a .05mm (.002) feeler gauge but i dont know how to use it correctly. this is what im doing. i put it under the tappet at the bottem and tighten the tappet till there is a little slack on the feeler and then bolt it down? or do i tighten down the tappet till the fellergueage cant move? any help? thanks!
You actually need the next size up and next size down as well. When it's adjusted correctly, you'll be able to insert the correct size, and feel friction, but not be able to jam the next size up in there.
I adjust until there is a slight drag on the feeler gauge. You can double check with one size larger and one size smaller, but if there is a slight drag, you are correct.
