CRF450 Master Cylinder will crf250 cylinder work?
I would like to do this mod and I see many crf250 master cylinders on eBay.
Will it work the same as the CRF450 master cylinder? :banghead:
I do have another question. Do you use your same plastic container and just hook it to the new metal master cylinder? Most are sold with just the metal master cylinder and the plastic container is not included.
You will not need the plastic reservoir with the new master. The CRF's use an internal reservoir.
The plastic tank bulging in one of the problems with the stock set up. The soft pedal feel is the other.
Compare the CRF250 part number to that for a 450 to see if they are the same. :banghead:
Thanks for the info! So you just take the lid off the metal cylinder and fill it there. Cool!
