Front Sprocket Removal?
Im replacing everything out with all Renthal. I still need to go out tomorrow to get some Allen Bit Sockets, so I can torque up the rear sprocket. Ok, now this may sound stupid, but how in the world do you get the front sprocket off.
The easiest way to do it is to crack it loose while the chain is still on the bike. Take the bike off the stand, put it in gear, and have your fattest friend sit on it and lock the rear brake. It will be easy to loosen then.
Thats how I do it. But I hold the brake with my foot while leaning over the seat and loosen it that way.
  • 10 years later...
Maybe too old, first dual sport, CRF250l. Changed to 13 tooth today. Had hell of a time with keeper. Question. Does the keeper hold the sprocket away from the case a little. If I have it bolted in does it not have to be in correct position? Went for short ride, speedo is off of course and nothing flew off. The u-tube videos are not clear on positioning the keeper.
