Aftermarket gas cap? Manufacturers?
I am in need of a replacement gas cap for my E. I bent the inner metal breather section on my OEM one and air will no longer pass (how I did it is a stupid story - don't lean your bike over to lend gas to a un-prepared friend, unless you do not plan on pinching the cap between the tank and the upper triple). I tried to straighten it out, but no luck. I starve the tank of ventilation about every three minutes as it is right now.
I do not mind buying a replacement OEM cap, but as long as I am spending the bread, why not get a little "bling" (AKA billet) to go with it? I have searched for aftermarket manufacturers without much success. BRP's runs around $50, and that's not going to cut it. I'll go back to stock if that's the case...
Sweet, but it doesn't fit an "S" 🤣🤣
Neil. :banghead::banghead:🤣
how can that be - the petrol tanks are the same aren't they?
Doesn't say anthing about not fitting an 'S' on the website
The "E" has a plastic tank, and I assumed they use different caps :banghead:
"EDIT"
For "S"
CAP SET, FUEL TANK 44200-29820 $84.89
For "E"
CAP ASSY, FUEL TANK 44200-29F00 $21.34
Neil. :banghead:🤣🤣
yes S and E models have completely different fuel caps, if you need an S cap I reccomend the dealer , make sure you get the non california cap
